REL 212/SE Subwoofer Overview
HTKamikazee
Audioholics Sheriff
What happens when you combine 4 bass drivers powered 1,000-watt amplifier? That's exactly what I've been asking myself since I heard the news from REL's new 212/SE Subwoofer.
This impressive unit features two active cast alloy front-firing woofers, one passive back-firing radiator and another passive down-firing radiator, all powered by a NextGen3 1,000W (1,700 peak) power amplifier. According to the company, this interesting array makes it perfect for either 2-channel setups and home theater systems.
This is what REL had to say about the 212/SE:
"To produce our highest output single-box solution, we doubled up on the Continuous Cast TM Alloy Bass Engines that bring critical acclaim to Serie S, altering them slightly for this twin front-firing configuration. These twin actives are responsible for 212/SE’s incredible speed and tactility.
Our Continuous CastTM Alloy Cones reduce moving mass while maintaining rigidity, producing far more speed and precision than prior designs. These twin long-stroke 12″ bass engines, partnered with (2) matching 12″ passives provide the speed quality of a REL with a power never felt before. This combination offers the driven surface area of twin 17” drivers in a cabinet just 16” wide. This design allows each driver to output over 110 dB with ease–power enough to drive very large rooms to very high outputs."
Check out the back-firing radiator and amplifier controls:
Here is a close view at the down-firing radiator:
Well, what can a say? I know, know; it isn't cheap. For $4,000 there much to expect from this unit, but given REL's reputation, I believe that this unit could surprise the subwoofer market. We'll see!
SOME FEATURES and SPECIFICATIONS:
  • Freedom LongBow™ Wireless Connectivity.
  • The down firing passive produces deep, floor-crawling bass that makes a room shudder.
  • Its glossy finish is available in white and piano finish.
  • Dual Continuous Cast Alloy Passive Radiator.
  • Twin Continuous Cast TM Alloy Bass Engines.
  • Receiver for wireless connectivity. (You need to purchase REL's optional wireless transmitter to use this feature.
  • Next Gen3 1,000w Digital Amplifier.
  • Dimensions: 32" (H) x 17" (W) x 20 (D).
  • Available: April 2015
Price: $4,000.00
Click on the following thumbnails to zoom in and don't forget to share your impression with us!
BoredSysAdmin
BoredSysAdmin
Passive engine is an oxymoron. Also I'd rather get psa triax or gamma 218
3db
3db
I honestly hope that this sub is not another one of those models that have a narrow band and are extremely peaky in their response judging from past reviews I've read.
