I have a pair of ACI Saturn subwoofers that I purchased/assembled in 1990. I initially used them with a pair of Dahlquist DQ-10's and a Audio Control Richter Scale Series III crossover/equalizer. Each sub has 2-12" drivers arranged in a push-pull arrangement at the bottom of a tall (~4 ft) column . They were great for music but recently got a little out of sorts when I pressed them into service for the HT stuff. Lo and behold I discovered that the woofer surrounds were laying at the bottom - disintegrated.
Right now, I am going the cheapest route possible and refoaming the surrounds. But, longer term, I was wondering if I could reuse the cabinets and replace the drivers or even make them active subs....
The cabinets are approximately 15x15x ~4 ft tall! They are extremely well-built so I feel "re-using" them is a viable option.
I was hoping some of you knowledgeable types might make a suggestion for my next step?
Stay with the refoamed woofers?
Put in new drivers? What are the popular/desired/best for low freq etc?
Stay with the push/pull configuration or go with std single driver?
Go active? Of course that opens up a whole buch of options.
My budget? Hmmm. I guess about $1000 to redo both units.
Thanks in advance for your help!
