Refoaming Mach Ones
I
Ice19
I am looking at buying some Mach One speaker, the second gen, they need to be refoamed. I found the kits on eBay, but I have never done this before and I want to know how difficult it is before I decide to undertake this project.
Any help or info would be great.
Thanks
WmAx
WmAx
Thanks
What do you mean second gen? There was the Mach One. Then the Mach Two. I have used both of these models in times past, and the Mach One is a far superior device in every possible way. The Mach One woudl be worth getting, I suppose, for some purposes. The Mach Two played off the name and used far lower price parts/construction to increase profits and I can not recommend the Mach Two.
Either way, www.partsexpress.com carries surround replacement/repair kits under the speaker building section.
-Chris
I
Ice19
By first gen I mean the 4024, the ones I was looking at are the 4029s which are still the Mach Ones but a different model
Rickster71
Rickster71
The second gen Mach 1 or the Mach 2's are nothing like the first gen Mach 1, #4024; as far as internal components.
It's as Chris said, Mach 1 is far superior. I agree, as long as it's the 1st gen #4024.
Save your money and time. The 4029's aren't worth it.
