Recommended features or models for sound bar?
bellbound
I have a large room and I would like to get a sound bar for my 65-inch TV, which might soon be replaced with a 70-inch tv that is mounted on a wall. Are there certain features I should look for? Are there certain recommended models?
Thanks.
KenM10759
KenM10759
You're the one who should be defining which features you need in a soundbar. That said, they're not often good for a large room unless you're sitting within 6 feet of it.
What will you use it for, 100% TV and movies, or will there be some portion of music only? Do you have plans for a subwoofer? How big is "large" in terms of actual room size?
