Recommended 2ch amplifiers under £100
Robert94
Robert94
A friend of mine is after a new amplifier for 2 channel set-up that is under £100 and has the potential to run upgraded speakers on in the future.
He currently has Wharfedale Diamond 9.1s:
Power handling 20-100 watts
Impedance 6 ohms
Sensitivity 86 dB
They are currently looking at a Cambridge A5 amp secondhand from eBay for £70. I was wondering if you guys had any other recommendations and if you think getting a second hand amp is the way to go as you can get some good deals - I'm very pleased with my second hand azur 340a.
BoredSysAdmin
BoredSysAdmin
Just to clarify things a bit: A5 is a Integrated Amplifier - means it has volume control.
Regular amps don't - they just amplify by fixed amount.
Given that A5 msrp is 120 of your queens currency :), 70p for 2nd hand doesn't sound to me like a great deal. It could've been purchased on sale new for 80-100p
Though I don't have personal experience with Cambridge products - I think they are making solid products.
Your Azur 340a is obviously more powerful than A5.
I would recommend to look for second hand Yamaha receivers - they are bulletproof and great value.
Robert94
Robert94
Ah thank you for the terminology clarification! :)
Looking at the specs the A5 has 60W per channel but my azur 340a is only 40W per channel.
Regarding Yamaha I've mainly only really seen them as a AV company rather than an integrated amp company (although I've never really looked so that could just be my ignorance). I'll have a look for some.
BoredSysAdmin
BoredSysAdmin
I was looking up specs here:
http://www.whathifi.com/cambridge-audio/azur-340a-se/specs
it's says 80rms - typically power specs is proved per channel. If they summed it? it's possible, but misleading imo
Besides A/V receivers, Yamaha have plenty of stereo only models - and they include robust and very clean amp section as well as more inputs and flexibility than integ amps do.
Robert94
Robert94
I find the whathifi specifications to always be off.. In the user manual it is 40W per channel, but I run B&W 685 S2 (recommended 20-100W) and I have never needed to turn it up to more than 3/4 volume so it's been pretty impressive (although my first hifi system so I haven't been exposed to anything else)
I'll have a look around for some older Yamaha models, thanks!
Seth=L
Seth=L
Economies of scale would drive me to purchase an AV receiver long before an integrated amplifier with that strict a budget. AV receivers offer a lot more features, power, flexibility, and at least equal sound quality to integrated amplifiers in that price range.
