Hi all,
I'm searching for in-wall speakers to be used as surrounds in my system. My frontal setup is B&W (603-S3 fronts and CC6 center), but I won't have conditions to buy B&W speakers for surrounds at the moment, since they are quite expensive here in Brazil.
To make things more complicated, I'm suffering of a health problem of high auditive sensibility, so that "BRIGHT" speakers are a hell to me. Because of this I would like to get some speakers that sound as "WARM" (or even warmer) than my B&W setup.
Someone over here suggested me that a pair of Absolute Acoustics FX4 in-wall speakers would work fine as surrounds in my system. Given that I don't have how to check this before buying, I would like to know:
1) Would you also recommend the above solution?
2) Which other options would you also recommend to me?
Thanks,
Demetrio.
