Why do you have different speakers for the back? Also, what sort of mods?
In my home-office I use bipolar speakers for the side surrounds. It just gives a more defused sound because you have two mid-woofers and tweeters firing off at angles spreading the sound along the side walls like at a movie. They're usually mounted higher than monopoles which made mounting easier in my situation. I do the same in my master bedroom. On the other hand I use monopoles in my family room. It's mostly positioning and personal taste. Go with whichever solution you personally prefer.
In the past I've used the little
Wharfedale WH-2 surrounds. They aren't the best speaker in the world but they're probably the best bipolar surround that you can buy for $80/pr.
A former member named WmAx came up with the B2030P mods. There isn't a lot to them. A couple of drops of liquid super glue between the woofer magnet and shield, a tiny bit of speaker caulk as a seal between the tweeter and wave guide, and replace the speaker stuffing with as close to 2" of sheet rockwool on all sides and 3" on the back as you can fit without blocking the ports. Not counting shipping you're looking at $1 for enough speaker sealing caulk for a dozen B2030Ps. A sheet of 24x48x2" Roxol Rockwool (enough for 4-5) is like $13+S&H. And a big can of 3M 77 spray glue to hold the rockwool in place is like $10 at your local hardware store. You'll need a Phillips screwdriver, a straight edge, a long razor knife, a place to work, and about 1/2 hour each. Cheapie surgical style rubber gloves from the hardware store are a plus unless you like scraping glue and rockwool off you skin. . BTW: The specified amount of rockwool doesn't leave room for the woofer so you have to cut away enough to let the woofer fit.
Honestly I'd just use them as-is for a while and see if you what you think. I think you'll be happy with them as-is.
