Recommendation for Wifi Interface
Bushka
Hi all. Long time since I've posted here. I'm looking to connect to Sirius XM by connecting a Wifi box or interface (whatever it is called) to my existing old amp. I'm looking for a recommendation for the cheapest one that works. It is for a deli so I don't need the highest quality sound. It's noisy enough in here that subtle quality differences don't matter. I don't want a POS, either, just something that works. Any suggestions?
Thanks,
Dan
Eppie
Eppie
Thanks,
Dan
Need a little more info on the Sirius XM equipment. Do you already have a Sirius satellite receiver or looking to purchase one? They are usually portable and can be moved around, possibly close to your amp? Sometimes the position of the Sirius receiver is critical for proper reception, so maybe it has to be far away from the receiver. If you can run an audio cable, that's best. If not, need to know if the Sirius receiver has RCA output jacks. You would then need a bluetooth or wifi transmitter / receiver combo unless the Sirius has bluetooth or wifi built in?
