Why not go with last year models, which have better power supplies and weight more (pounds), and cost much less too?
The best one is the Yamaha RX-V663, which you can probably have for a very good clearance price. OK, it does have only 2 HDMI inputs, but can you live with that?
If not, go with the 665, which have more features and less power, plus cost more.
Did you also look at the new Pioneer models, the VSX-1019AH-K and the VSX-919V-K? They are fully loaded and within your price range too. Of course the 1019 is the better one.
If you really want to go for the bottom price, consider the Pioneer 919 or Yamaha 565.
And if you still want to go very LOW, check the Pioneer VSX-819V-K or Yamaha RX-V465.
Do you want 5 or 7 channels?
Lower than that is e-bay, where you can get an older model receiver for about $40.
So, here you go, from a high of $400 to a down low & dirty $40.
Pick the one that match your desires and your budget.
Bob
