Lets be fair, and give him a really good recommendation... .
I would recommend getting 4-5 Mcintosh MC2102 amplification units... Then find a Pre-Amp... hmmm lets see Halcro SSP100 should meet your needs.
You need 4 or 5 because of the number of outputs you got in the Halcro, and you sure do want to use all of them... That should make you very happy... though it may be a bit more money then that Denon, it is worth every penny.
Ok... so Im beign a bit harsh, and a bit funny. Im personally looking into a good HDMI compatable receiver for under $1k. They will be powering a set of B&W 603's with either a LCR600 or LCR60 (depending on what I can get them for).
I only want a single HDMI source (or maybe a pair if needed). But the AV Receiver has to have 5.1 coaxil inputs. I am going to be hooking up my computer to this system, which will blow the doors off of any CD/DVD player out there that is under 1-2K. I will also be building a Media Center for another room, that will have the ability to record multiple shows at once, and then share them with my main computer thats on the LCD. Therefor I am not interested in more then a few components. What I need is POWER! Clean, Clear, Power with amazing sound.
Any ideas where to start?
