Recessed onwall speaker plate - exists?
V
VideoScuba
I've decided to go with on wall speakers for my HT set up - I know most folks would just cut a hole in the sheetrock (or cut a hole in a blank wall plate) to run the speaker wire to the speaker - I was hoping for a slight more elegant solution...
I'm looking for something like a recessed speaker wall plate that would allow access to the terminations below the surface level of the wall (essentially a recessed wall plate).
I swear I've seen something like this where the wall plate is actually a small box and the terminations are available slightly recessed...(I've searched the web, couldn't find something like this).
If you know a source for something like this, please share...
Thanks,
- Matt
MACCA350
MACCA350
Try Parts Express under speaker building, these are similar to those recessed on the back of speakers, I'll PM you the link
cheers:)
Tomorrow
Tomorrow
Thanks,
- Matt
Something like this? http://www2.dvigear.com/dviwallplates.html
majorloser
majorloser
Moderator
Elegant Solution- MAYBE
Yes, they do make recessed plates but you would still end up with wire that require hiding behind the speakers.
Here's what I did with standard 5-way binding post plates:
http://s58.photobucket.com/albums/g278/majorloser_pics/?action=view&current=Crib054.jpg&refPage=&imgAnch=imgAnch9
http://s58.photobucket.com/albums/g278/majorloser_pics/?action=view&current=Crib035.jpg&refPage=&imgAnch=imgAnch16
I made a small frame that fills the space between the surround and the wall. At the top of the frame is a screw for hanging the speaker. Painted it black and hung it with screw-in drywall anchors.
It was either that or you can use a low-voltage old work box directly behind the terminals. This way the wire can stay in the box/hole-in-wall.
