I just picked up a used Marantz SR7001. I can get it to play via optical from my Onkyo DV-SP502 player, but for some reason when I try to stream from my PC the display says "no data."
Only two days ago I was happily streaming music from my PC onto my Yamaha RX-V667, so I'm pretty sure the PC is still outputting properly. I've tried connecting via all 4 of the SR7001's optical inputs, but none of them will recognize a signal from the PC, though they work with the SACD player.
I've been trying to play .flac, .mp3 and Apple lossless in both iTunes and Foobar2000, and I get nothing. None of the system sounds are working either. The Yamaha recognized the signal as PCM, but as I said, the Marantz just says "no data."
I'm running Win7 64-bit and using the on-board optical output. The drivers and codecs on my PC all seem to be up to date. I've tried reducing the sample rates to no avail.
The Yamaha is only a couple of years old (2010), but the Marantz is from 2007. Could that be the problem? The SR7001 picks up the optical PCM signal from the DV-SP502 just fine. Could it be a software or a firmware issue?
Any help would be greatly appreciated!
