Try phasing..i dunno if it is a setting or not,but you can always..
you can always try flipping the phase of the inputs to your sub,i do this all the time in cars.. you never know what works best,you have to try..
i mentioned this on another forum,flip BOTH the inputs to your sub(unless of course,if it is a mono input!!!then just flip the one set..)
both +'s where the-'s were,etc..
in the vehicle,this is usually a menu setting,the car is what i am used to soooo....
try it,you may be amazed at the results..
this also applies to front,and rears as well,you never know until you try..
without getting into too much audio theory,One way,or another is always better! i suggest you try it,how far away from a wall,the freq limits, the size of the room,all may affect(effect??..i never remembered!) the situation..
try:
fronts out of phase
rears out of phase
subs out of phase,
the couple other permutations,i think only 5 total?(not a math whiz,but you get the idea..)
depending on the relative distance of the fronts,to the center channel,(i doubt it,but it's easy to try!) try the center out of phase as well..
you should try these things,then CLOSE your eyes,try to picture stuff,it may be weird(probably not the right combo) or amazing!!
like i said in another post,'swordfish' seams to have the 5.1 thing well worked out,i use it to test 5.1 systems in the car..it is easy to relate to your position in the scene(ok,you might want to open your eyes from time-to-time!!)
you get the overall idea..i hope..from what i have read so far,the people here seam to actually understand something about audio!(duhh..hence the name??audioholics..i think most of the car audio kids are related to the alcho--version)
enough babbling,i do that,but it's just because i am trying to help!
