94txh
I have sound coming out of my subs.I have sound coming out of my headphone jack. But I have no sound coming out of my speakers.
I tried changing hdmi. I tried extended stereo. I tried multi channel in.
Did the amp go out? Can I test this?
Try a hard reset. That is always the place to start. This does not sound like a software problem but these days you never know.
I suspect however the section of the power supply that supplies the power amps has gone down. The power amps run at much, much higher voltage than the voltage gain and processor sections. Headphones and the sub out does not involve the power amp section.
If you do have a local repair shop this is a fault that may well be easily fixed. The problem is finding someone to look at it.
