I am putting a system together for my Great Room: 15' wide, 16' deep, 11' flat ceilings, carpeted, budget of $1500 for speakers, sub and receiver. It opens to the eating area so there is no back wall. I need a nice sounding system with in walls and in ceilings for surround. I would like to have a 50" or so plasma or LCD. I like the Panasonic TH-50PX60U or TH-50PHD9UK. Any suggestions on others in the $1500 price range. I would like to hang the TV on the wall to save room. I want in walls/ceilings to save room, for asthetics, and because I don't want to see my daughter pull a speaker down on herself. I will be using the system for TV/Movies 60% of the time, listining to music 30% and playing XBOX 10%. The XBOX 360 will be used for playing DVDs and CDs and will be connected to the receiver via a Monster Cable component cable. I will use HDMI from the cable box to the receiver and from the receiver to the TV.
I work at a place that sells A/V components. My price on some of the receivers they sell:
Denon AVR 1707 $320, AVR 2307 $570
Onkyo TX SR505 $260, SR 575 $340, SR 605 $405
Harman Kardon AVR 247 $390, AVR 347 $600
Sony STR-DG910 $380
Yamaha RX-V661BL $360, V861BL $640
I want 7.1 in case I upgrade from 5.1 someday. I also need HDMI and XM radio compatiblity.
For speakers, one of the installers at my work suggested Niles HDLCR ($165 ea) for the front 3 speakers and 6CMHDFX ($195 pair) for the surround in the ceiling with a Klipsch RW-12d ($440) for the sub. I asked about Klipsch for the in walls and he said unless I went with the KL-7800-THX ($475 ea) I wouldn't have a matching center channel. I don't know why I couldn't use three R5800-s ($165 ea) for the fronts and two R5800-c ($165 ea) for the surrounds? My work also carries JBL, Infinity, and few other brands. I have seen others suggest Paradigm for in walls so I listened to what I was told were the bookshelf eqivelent of the PV 160's today. They were less than impressive. The salesman told me that was the best I could afford in that brand with my budget. I see Polk sells enclosures for their in walls. Would something like that help other in wall speakers? Any opinons on my situation would be appreciated. I know in walls/ceilings won't make for the ideal HT, but I'd really like to keep the room looking clean. Maybe in couple of years I can finish the basement and do something better down there. Thanks.
