I planing on purchasing the yamaha rx v373 receiver (I will list the specs bellow I just want to no if this receiver will be good enough or is it not enough power I currently have 2 polk audio monitor 60 cs2 center and monitor 30 bookshelfs I just want to make sure I have enough power to handle all the speakers I will list the specs bellow
Reciver: Amplifier Section Channel 5.1
Rated Output Power (1kHz, 1ch driven) 100W (8ohms, 0.9% THD)
Rated Output Power (1kHz, 2ch driven) 85W (8ohms, 0.9% THD)
Dynamic Power per Channel (8/6/4/2 ohms) 110/130/160/180W
Monitor 60s: Total Frequency Response 38Hz - 25kHz
Upper -3dB Limit 24 kHz
Lower -3dB Limit 48 Hz
Nominal Impedance 8 ohms
Efficiency 90 dB
Recommended Amplifier Power 20 - 200 watts per channel
Inputs Dual (bi-amp) 5 way binding posts
