Good morning all,MY question I am using a okyo R506 receiver,infinity primus 162 front R+L ,primus 350 center,primus 210 sub and 142 rears.panasonic blueray,samsung 50" plasma,is the receiver I am using enough for the system or should I upgrade it,and if so what 5.1 receivers would you recommend? I only use the 5.1 and will never use 7.1 due to the size of the room and I wont be moving being I just built this house.I am fairly new to learning about home theater but really enjoying it ,I have been upgrading my components little by little and my receiver is the last if the pros think it would make a difference,The big thing is if I do upgrade would I hear a difference in sound quality,I know the new receivers have better decoding but does that equal better sound? thanks in advance for the help and suggestions.
