I will appreciate any advice you can give me in picking a receiver.
I am mostly considering a
Yamaha RX-V1500 or a Denon 2805. While price matters, if the features for the price point make sense for me to consider something else then I will, for example a
Yamaha RX-V2500 or a Denon 3805. If there is something else then I have missed it in my research.
I am piecing together a system from parts of a previously shared system, my old bedroom system, and gifts. I will be upgrading pieces as I can and my first purchase will be a receiver. It is my understanding that it will aid you to know my current components, how I will use the new system, and where I will use it.
My current room is approximately 14 by 17 with 9 foot ceilings. I will be moving in about a year but the new room should not be much, if any, larger. The system will mostly be used for TV and DVDs, especially science fiction but it will be my only system, so it will also be used for music, mostly classic rock, jazz, classical, or new age. I rarely crank up the sound.
My current components: Toshiba HDTV 34HF81;Toshiba Progressive Scan DVD Player SD-3800; Panasonic SVHS VCR PV-S9670; DVR cable box - waiting on HD DVR box; L/R front speakers: Bose 601 series II - these were a gift
; Center Speaker: using TV (has audio in for center) - my next purchase?; L/R rear speakers: Niles OS6 - previously my porch speakers; Subwoofer: Sharper Image SA251 - I realize this needs to be upgraded but it was fine for the bedroom and is better than none; currently unhooked/packed: phono & cassette player;
current receiver: Yamaha RX-V592 (not even SVHS) - an obviously badly needed upgrade.
I would like the receiver to have video up-conversion to component, front inputs, and a comfortable learning remote. A phono input would be nice as sometimes I get nostalgic. An on screen GUI display sounds nice but I am not sure how much it's really needed. Once you get passed here, I am not sure what are bells and whistles, what are nice features, and what is sales bull. For example, 5.1 surround is obviously a minimum but will I miss 7.1 in the (near?) future if I don't buy it now? Is it true if you purchase a receiver online then the manufacturer does not honor the warranty? Does YPAO make things easier to setup or not even work at all?
I have tried to educate myself on ohms and watts and programs. I even have the spreadsheet to prove it. In a perfect world, I would hook-up and play the various receivers with my components but that isn't going to happen. What should I try to accomplish at the store? online? I understand that my Bose 601 series II speakers are fairly mellow speakers. If that's true ,then will asking to listen to both receivers in the store with the same mellow speakers help me decide? If yes, then do you have a suggestion which speakers I should use for the comparison?
I realize this is a long post and want to express my appreciation to you for reading this far. Please accept my thanks in advance for your help and advice.
Las
