the "third pin" is the equipment safety ground. If the case is not double insulated from the hot lead, then it is required. However, the neutral line and the equipment safety ground are actually bonded together at the circuit breaker panel in your home. Then all the grounds, including the neutral, are "earth grounded" to the home ground rod. So, in effect, the neutral is also a ground.
