Houe
I have a set of klipsch speakers and I need to buy a receiver. I have four ksb1.1, a ksc-c1, and the matching klipsch 100W subwoofer. These aren't really high powered speakers so I don't need anything too powerful. The ksb 1.1 speakers are rated at 75W continuous if that helps. This setup will be mainly used for movies. What receiver would you recommend to complement this setup. I want to spend the amount of money that it takes to have a receiver that matches the quality of this speaker setup. No reason to have a super receiver if my speakers can't make use of it or vice versa. Hopefully its less than $450.
jcPanny
jcPanny
Receiver for Klipsch
I think an entry level $200 receiver like the Yamaha HTR-5840 or Onkyo 503 will be plenty to drive your Klipsch speakers. If you want 7.1 or more features, then look for a Yamaha HTR-5860 for about $350.
The Klipsch horn loaded tweeter is very efficient which means that they don't need a lot of power to play loud.
