I'm looking at purchasing the JBL SCS140 5.1 speaker system (spec below), but being a newbie to all this, haven't really got a clue about what receiver I need to hook up to it. I'd like to get good sound not only for movies, but equally for playing music too. I'd also like a digital optical input on the receiver too for hooking up a computer which has digital optical out to the receiver in future. Any recommendations or advice? Thanks.
JBL SCS140
System Section
Frequency Response (-6db): 35Hz - 20kHz
Active Subwoofer Section
Low Frequency Cut-off: 35Hz
High Frequency Cut-off: 160Hz
Built-In Amplifier Power: 100 Watts RMS
Drive Units: 200mm Paper Cone Long Throw Driver Bass Reflex Enclosure
Dimensions (H x W x D): 410mm x 280mm x 376mm
Weight: 12.7kg
Satellite Section
Frequency Response (-6db): 120Hz / 20kHz
Sensitivity (2,83 V @ 1m): 86dB
Nominal Impedance: 4 Ohms
Recommended Amplifier Power: 10 / 50 Watts RMS per Channel
Drive Units: 12mm Titanium Laminate Dome Video-shielded HF 75mm Paper Cone Video-shielded Midrange
Dimensions (H x W x D): 111mm x 81mm x 95mm (4.4" x 3.2" x 3.7")
Weight: 0.5kg (1.1lb)
Center Section
Drive Units: 12mm Titanium Laminate Dome Video-shielded HF Dual 75mm Paper Cone Video-shielded Midrange
Frequency Response (-6db): 120Hz - 20kHz
Sensitivity (2,83 V @ 1m): 88dB
Dimensions (H x W x D): 83mm x 194mm x 95mm
Weight: 0.85kg
