mike c
Mate you’ve got the formula all wrong this is how its done no ifs no buts this is how its done.
Note the height surrounds that are positioned at the back, and thou I still have at least a few more to add around four more so that’s six for the height surround.
Plus a few more for the sidewalls one for each just in-between the two sidewall surrounds and one on each sidewall again placed nearer to the back, and with careful balancing of the levels as well as equalization and loudspeaker management system to customize the performance.
Most home cinema rooms I’ve looked at seem to have only four loudspeakers for the surrounds and this where you guys get confused even muddled up with all the home cinema magazines.
5.1 doesn’t mean that the surrounds should be comprised of just two same with 6.1 7.1. The rule is the surround loudspeakers should be set-up in horseshoe configuration.
I’d say a room that size would need at least 4 or 6 loudspeakers for the back wall and 4 to 5 spaced out evenly along the sidewalls, that’s if you really what to make it surround the listening area as well as sound darn right impressive.
Now I’ve been using this array in my home cinema now for 1 year and it sounds like the cinema in a small room with big impact, now then.
The total cost for the surround array set me back £249.99.
