Sheep said:
Actually, that is incorrect. The surrounds don't have to match the fronts, but they have to match eachother.SheepStar
UNTRUE. Unbelievable! Not really...some people just like to hear themselves speak. I don't know precisely what you're disagreeing with, but you assume too much if you infer that I meant you could match a Paradigm minimonitor left surround with a B&W 602 right surround, and be pleased with the results.
I simply made the following statement, and stand by it:
Timbre-matching is not necessary with the surrounds (
to the fronts or center. I ommitted this statement, but this is a
reasonable inference). But this assumes you "have
good matches to begin with."
Although ideal, side surrounds and rear surrounds do
not have to match each other, assuming they are "good matches to begin with." This is all academic for those who are purchasing entire surround systems at once...why would you not match the rears with the sides? I can think of no logical reason other than 1) economic, in which case, I would submit to wait until one can afford to match the system, or, 2) space, in which case, if you're looking at in-wall or in-ceiling (for the rears, but not the sides), this entire discussion is moot.
The clear intent of my statement was for those who are shopping for rears and are trying to match their already discontinued sides. This point has been argued to death, and I stand fast that
rears need not timbre-match the sides (in your words, "they have to match each other"), assuming that they are good matches/mates to the sides, as well as the mains and center. But I take for granted that this was assumed by all to begin with. Who would be so foolish as to meld some overly-bright Cerwin-Vegas mains with a very warm Aperion center, or surrounds, for that matter. But I'm sure it happens.
Absolutes and incorrect corrections is a sure-fire way to instigate a match (as you did with P****, I will not speak his name). My suggestion is this: rather than writing:
"Actually, that is incorrect. The surrounds don't have to match the fronts, but they have to match eachother.", it would be less confrontational, and far more accurate to write:
"Actually, I disagree. The surrounds don't have to match the fronts, but it is best they do, as well as match each other."
Just my $0.02 worth of wisdom for the day.
