rear center speaker
jjclecky
I wanted to add the rear center speaker (6.1) my problem is couch is right on the wall so I was going to put a 8'' in ceiling speaker for my rear center, would this be a mistake?I cant put it on the back wall because like I said the couch is there, would I get accurate sound being that its in the ceiling and my front center is under my plasma I am using all infinity speakers.thanks for any advice
STRONGBADF1
STRONGBADF1
I don't think I'd bother. I'd look for another upgrade that would be more beneficial for the system.:) That placement just wont be worth it IMO. Maybe others can chime in with advice to the contrary...
jjclecky
what would be a goodsuggestion of a beneficial upgrades,I have a blu ray player 50'' plasma, infinity speakers, onkyo sr506 receiver thanks in advance.
walter duque
walter duque
This is how I set my rears up. I am very limited with space too. For me it works. It's an odd set-up I know.
jjclecky
did you set the rears at the same db as all the other speakers
