I’ve been testing an ES9038Q2M DAC module, which supports 32-bit/384kHz and DSD. Compared to the more common PCM5102, it offers higher dynamic range, cleaner lows, and more detailed highs.
However, this chip is quite sensitive to power supply and clock quality—using a basic supply easily introduces noise. To get the best performance, it’s better to pair it with a low-noise LDO or an external clock.
Here’s the
ES9038Q2M datasheet, which provides detailed specs and interface information.
Has anyone here tried ES9038Q2M in a home theater setup? How does it compare to PCM5102 or AK4493 in your experience?
