Re-establish wifi on RZ50
Squishman
Squishman
My tablet lost the connection to my RZ50. How do I re-establish that? I imagine @Trebdp83 know what to do. One thing cool you can do with the app is set any pair of speakers as mains. For some fun, I want to play some LP's through my new heights and compare them to my La Scalas.
Trebdp83
Go into your Onkyo on screen Setup> Select Hardware> Select Network. If using WiFi and your network does not show as connected, switch WiFi OFF briefly and then back ON. If it does not connect automatically, select it from the list of available networks and enter your password.
You can also use the remote controller to move the stereo signal to another pair of speakers. Press the Quick Menu button> Select Audio> Select Stereo Assign and then select the desired speaker pair.
Squishman
Squishman
Oh great about the remote. I got the connection back too. Thx!
