I'm just not that comfortable buying stuff online...but you're both probably right, best prices are online. I'll def look into it. Thanks for the info.
I, personally, would be more worried that you are considering any brand that is carried by Wal-Mart. If you are tight on cash, and have the foresight to come online to ask questions about what is worth buying, then you can avoid the horrendous mistake of spending your money on lousy quality.
Don't get me wrong, my RCAs have held up, and I think a Sanyo will as well, but they don't exactly stand ahead of the crowd, for your money, for actual overall quality. That is, the actual image you get on screen - and will have to live with - for years to come. It's like they make perfectly reliable cars, that can't go above 55mph... Yet, the cars that go 80 or 90 are available for the same price if you are willing to shop around.
Yes, online can be a bit risky... but only if you buy from risky etailers. Stores that sell online are often covered in resllerratings.com and can deliver to you first rate customer service and quality. Keep in mind, if you go to Best Buy and buy a plasma, they aren't going to open it. That is, it was shipped from the factory to the US on a boat, then was carted by truck and train to the store, then ends up in your home - never once looked at outside of the factory. So, while it does happen, it is still very rare for a plasma or lcd to be damaged on the last leg of the trip from the etailer to your home.
For big online purchases I have used many sources, but for my projectors I have used VisualApex.com three or four times and their overall service has been better than almost any brick and mortar store I have ever been into - and worlds better than Wal-Mart has even dreamt possible.
