lovinthehd, thanks for digging around, but maybe I should have mentioned this is a different setup. The Yaqin integrated mentioned in my other thread is not used atm.
In this case the AVR is a Denon X3300, the preamp an old NAD C160 and the power amp is a Lyngdorf SDA 2175.
ski2xblack, the reason for doing this is that the AVR's preamp section sounds worse (in PureDirect, other modes are even worse) even than the old NAD preamp. Also I plan on upgrading the NAD with a tube preamp in the near future.
There are some secondary reasons as well, like the exterior DAC (SMSL M8A) being again of higher quality than the AVR's DAC (not that in this case I can 100% verify that, to my hearing if there is an actual improvement it is more subtle), supporting native DSD (again - questionable benefits tbh), allowing me to hook up the headphone amp (which the AVR does not allow), etc. But that is not entirely related to this RCA switching issue.
BMXTRIX, yeah, I am considering adding another switch. The thing is - there already is one switchbox in the DAC to pre-amp chain (helping with the hook up of the headphone amp) and I wanted to avoid having a switch, therefor I was opting for the more simple solution with the hard RCA Y-splitter.
Y-RCA = simple metal; no wires;
VS
Switchbox = circuits; even wires in some cases; not to mention attentuators and additional gain in some; overall more complex.
But I guess a switchbox might be the safer way to go in the end.
Leemix, any particular reason why not to do the Y-RCA splitter?
My point is overall I just want to make sure if there is some scientific explanation why I could damage the power amp by accidentaly feeding it 2 signals at the same time (1 from AVR, 1 from preamp) and/or degrading audio quality more, because of the 2 outputs (preamp + AVR) being hooked up to the power amp at the same time, having higher load, resistance, or I do not know what else.
A lot of thanks to everyone! I really appreciate all the help, suggestions and information.
