Two RCA AVHDD DVR2160 external HD hard drive recorders. Originally designed for a TV with a 1394 Firewire port (Samsung, Toshiba & Mitsubishi) to record digital programming. One is fully working, the other has a bad interface board, but the power supply and the 160 GGB HDD is fine. Tested ok. Can be modified to use as a external HDD enclosure with a SATA HDD by adding a cable. Original HDD can be used as a spare HDD inside a PC. $90 for fully working, $65 for one w/ bad interface board.
