RBH TK-515C center replacement
chris6878
Hi I purchased the TK-5ct some years back based of the reviews here. I would like to buy a center channel that matches these speakers since they are discontinued. What else is available. MY budget is 0-500.
Thanks for any help
Soccerkid830
Soccerkid830
You can still find the TK-515C in stock at some dealers.
RBH TK 515C 2-Way LCR/Center Channel Speaker
I've never used these to sites before so be a bit diligent in you're research on them.
From RBH's website. So be VERY careful if you're going to buy off these sites. On RBH's site, you can find local dealers and such. I'm currently looking for a T1 to add as a center channel but I do not have any dealers even remotely close to where I live, so I'm just waiting to see some for sale online for the time being...
BUYER BEWARE!
The following ARE NOT Authorized Dealers for RBH Sound even though they have been known to offer RBH Sound products for sale:
www.elegantaudiovideo. com
www.audiophileliquidator. net
www.superiorhifi. com
www.independentaudiovideo. com
www.bestofaudio. com
www.newaudiovideo. com
www.hifisoundconnection. com
GranteedEV
GranteedEV
Thanks for any help
How about the EMP E56Ci, made by the same people at RBH:
EMP Tek E56Ci Large Center Channel Speaker
or the Aperion Verus Forte Center:
Verus Forte Center Channel Speaker - Aperion Audio
or the KEF Q600C:
KEF Q600C 6.5in. 3-way Black Center Channel Speaker | Accessories4less
chris6878
Thanks for the replies. I also emailed RBH directly. Ill report back when they respond.
In the mean time ill check out the suggestions.
Soccerkid830
Soccerkid830
Your equipment list looks amazing. :)
Thanks! Now I just need to be able to set it all up in one place. Everything in that list is currently in boxes in my mom's basement.
One more year til I'm done with school and hopefully I'll get a real job and my own place rather than apartments with crappy neighbors...
As for Chris,
Try emailing Brian from RBH/EMP at Brian@rbhsound.com
I recently sent a few emails back and forth with him about my T2's and he is very knowledgeable and helpful.
chris6878
Here is the reply from RBH
Hello Charles,
The MC616C or the MC414C would be the closest match. Both are in the next series up from the TK series but should work fine.
Thanks,
John
chris6878
IM torn between the EMP Tek E56Ci
and the MC-616c. Which one do you guys suggest? Thanks
avliner
avliner
If I were you I'd follow GranteedEV's advice, as to go with the E56Ci CC, made by the same folks over at RBH though ;)
