RBH review part 2
i had to break up the review into two parts given forum limits. sorry.
Random listening notes:
HD: “Mr. And Mrs. Smith”: One of the most enjoyable aspects of these speakers is their dynamics and realism. During the fight scene in “mr and mrs smith” brad pitt and angelina break a lot of stuff, and the broken glass scenes had an amazingly tactile effect that made me believe that glass was breaking right in my basement. Many good speakers can produce a sound “like” broken glass. Very few can convince you that there is now a lot of broken glass all over your basement floor.
DVD-audio: Beethoven Symphony #9: large symphonic pieces remain in my opinion the hardest test of any speaker. It is asking a lot of a square box to sound like 40+ different instruments playing at the same time. Large groups of stringed instruments often have a “sizzly” sound. Sorry, it's the best word I can think of. This is very annoying to me, as having 12 years of violin practice, i know what a group of string instruments should sound like. These 1266se come as close to correct as I've heard in a long time.
DVD-audio: Steeley Dan: the vocals are clear and clean. The bass is well defined. Interestingly, when i play it from the hard drive HTPC, the tempo is a bit fast. When played from the Oppo, the tempo is slower and more to what i am familiar with. The Axiom Sub is amazing and although i bought it for movies, it is clean and tight enough for music as well
CD: brian bomberg: jaco. This is my first brian bomberg cd. Overall i am more impressed with his technique than the actual music tracks. The bass is clear and the decay of the notes is well addressed. Again, the bass is tight and brassy with excellent detail and texture.
DVD: Master and Commander: during the first encounter with the “Acheron” ship, the cannon fire and subsequent explosive destruction of the wooden hull of the ship is very convincing. The rear 61se hold their own quite well as there is a lot of rear sound effects during this scene. The rear soundstage travels well between the 61se's. The center channel keeps pace with the front 1266se well and the dialog is clear and distinct.
DVD: war of the worlds: this is an amazing movie. The sound track far excels over the cinematography. I am just not a fan of the grainy washed out color scheme that steven spielberg seems to like in his more recent movies (saving private ryan, minority report, wotw). However, this is an excellent movie to demo a sound system with. The subwoofer got a severe workout and kept up with the movie well. The scene in the basement, where tom cruise meets tim robbins, has some excellent water effects. The sounds of the water dripping around the room, again, made for a convincing effect.
Summary:
Pros:
i am more than pleased with this system. If i had to describe it in one word: accurate. They are clean fast speakers that do the most important thing in producing as un-colored a sound as i've heard. The speed of the speakers is hard to describe. For lack of a better word, they sound fast. When glass breaks, metal dents, or wood shatters, or water drops fall, they all sound very real without being “bright”. They are not fatiguing even at higher volumes for extended listening sessions. These sound effects are not what most reviewers seem to focus on, but it is what singles out these speakers from other speakers that i've heard. I recently went to bestbuy / magnolia to listen to their setups, and although different room / speaker placement / source, etc... i did not hear anything that even came close. The martin logans were the only speakers that were in the same league. Their open airy feel, although very pleasant, was not as accurate to my ear. Yes, you could argue apples / oranges as not an identical setup, but the difference was not subtle.
Cons:
the bass from the 1266se is very powerful, and for music is sometimes too much. Especially with my front left speaker corner loaded. I think this is more a placement issue than a speaker issue. For 2 channel music i would not use the “direct 2 channel” mode as it runs an unfiltered signal to the fronts and is too bass heavy. Another option would be to disconnect the 12” from the biamp channels and just run the speaker top half. The rear 61se although excellent, are not an even match for the fronts. If i did it again, i'd opt for 2 661se for the rears and orient them vertically. (and is a possible “Upgrade” for my not too distant future...) The only other comment about the 1266se are that they are large and need a large room to project into.
Other changes? I'd have my installer run 2 sets of speaker wire for my fronts so i can bi-amp, or send the 12” woofer section just the LFE channel. Now that the walls have been patched and painted, it would be a costly change. I'm not sure if i'd hear a difference, but again, it would have made a little more sense to use in essence, all 5 channels with the same speakers. Plus, it would have made my switch to T2's more easy
Thx. i welcome your comments.
