It all depends on the DAC. I think more should be done with optical when equipment is spread around a house and I'm glad more small converters are available. That allows using a coax that may be available to send the signal in digital form from one end of a building to the other and then, by connecting a small box to it, convert to optical. This can be done in reverse, too. It literally eliminates the chance of having a ground loop and yes, that can be a problem on a digital coax cable.
I have seen optical leads that wouldn't transmit enough light when they were coiled too tightly, even though it didn't look like it was a small diameter. Too bad they don't show the minimum diameter on the package.
