You do need some way to find the in room frequency response, if you are think of using a Radio Shack meter and a CD of test tones, it's not the easiest way, but it's about the cheapest.
The reason the Radio Shack meter is usually recommended is because its response is generally known, and correction factors are available for its inaccuracies.
On another note, what kind of EQ are you planning on using?
