In case you have not read enough on the bi-amp topic on this forum, most posters don't believe passive bi-amping (i.e. still using the speaker's built in crossovers) improves sound quality. Some said so based on their own experience, others on hearsays. I believe theoretically you get a purer signal but will not result in any audible difference. The difference between passive bi-amping and just bi-wiring is very insignificant in theory, giving the same total power available. At the end of the day, if you believe the theoretical difference will be audible to you then do it. It is your time and money after all.
