Quick question, Need Quick Answer Please
G
GoodSon
Will the Yamaha RXV-2500 sufficiently drive these speakers: KEF 105's
Specifications
Frequency Range
49Hz - 20kHz +/- 2.5dB at 2m on ref axis (-6dB at 20Hz when used with KUBE 200)
Directional Characteristics
Flat within 2dB from 50Hz to 17kHz up to 30 degrees off axis
Maximum Output
115dB spl on programme peaks under typical listening conditions
Characteristic Sensitivity Level
93dB spl at 1m on reference axis for pink noise input of 2.83 V rms, band limited 50-20kHz (anechoic conditions)
Amplifier Requirements
Suitable for use with amplifiers capable of providing between 50 and 300W into 4 ohms resistive load.
Nominal Impedance
4 ohms resistive 20Hz-20kHz
Weight
42 kg (92.5 lb)
Dimensions
1104 x 280 x 405 mm
43.5" x 11" x 16"
Finishes
Black Ash, Walnut or Rosewood veneer
Z
zumbo
Should be no problem. Just watch high volumes for long periods with more than 2-channels driven. Should drive 2-channels without breaking a sweat! Those speakers are very efficient.
G
GoodSon
Thanks for the reply. Yeah, it will only be used for 2 channel operation. So that's good to hear!
