Quick Question - Denon vs Onkyo
slickguy
I have decided to get one of these but not very sure which one would be good. Any suggestions?
Denon - AVR 2112ci vs Onkyo TX-NR709
Other than airplay in denon, I see that Onkyo has more features.
Thanks for your feedback.
slickguy
Of course, the Onkyo has THX, but Denon does not. Not sure if THX adds a lot of value.
96cobra10101
96cobra10101
Lots of issues with Onkyo's lately, I would go Denon, Yamaha or Marantz.
3db
3db
I second that opinion. THX means absolutlely squat when the receiver craps out.
Lulimet
Lulimet
The Denon doesn't have preouts if that's important to you. The Onkyo does have preouts.
BMXTRIX
BMXTRIX
In my experience, Denon builds to a much higher quality standard than Onkyo has. You get more bells and whistles with the Onkyo, but their A/V receivers tend to run hotter and can overheat more easily. This indicates that their amplification section is not as robustly built as the Denons are.
This has traditionally been the case that Denon does not offer as many features, and the Denon bells and whistles outside of standard A/V receiving/amplification are weak. But, the A/V switching and amplification is one of the best in the industry.
I think of Yamaha, Pioneer, and Denon, that Denon has the most well built product. I think Yamaha is right behind them with perhaps a bit more quality in their add-on features. Pioneer gives a solid product for the money, while Onkyo gives lots of add-ons but falls short of almost everyone else in build quality. It's great for the entry level home theater in a box crowd who is just starting out and has a really low budget... But, once you want to get serious about your A/V setup, then there are choices which deliver higher quality, and Denon is one of them.
slickguy
Thanks for all the inputs, the only thing that worries me (being a beginner) is the THX part. Denon does not have THX, so was wondering if I watched THX movies, would it make any difference in sound on the THX certified receivers?
afterlife2
afterlife2
BMXTRIX
BMXTRIX
THX is a testing process which costs manufacturers money to attain. In return, they get to put a little sticker on their product which says 'THX'.
THX does NOT give this away for free, so if you want to claim THX certification, you have to PAY for it!
So, if you aren't willing to pay for it, does that mean that the product does not meet THX certification specifications?
No! In fact, because a company isn't paying for that certification, they often are putting more of their money into actually delivering you a better overall product.
There is no disc or compatibility issues or anything else about THX that has any relevence. For weaker companies, THX certification works nicely as a marketing tool, but for a quality company, such as Denon, THX certification is bascially just a huge waste of money.
slickguy
Great!! that makes complete sense. I will stick with denon avr 2112ci.
