Sorry, this is not a proper question. The issue has more to do with overall bandwidth and the final room transfer function effects, than anything having to do with the anechoic target function.
Servo systems, as a rule, make more difference on poor quality drivers which have poor linearity. On a high quality driver which has a high quality motor and mechanical linearity, a servo will not produce an appreciable difference in typical operation. You would have to drive the subwoofer into ranges where it was deviating from linearity significantly; with moder high quality drivers such as the Tumult, this is an extreme condition in which you would not normally use the driver.
If you are most interested in the 'best' sound for your prefernces, you will do as I do: you will use an efficient, flat response bass alignment with low distortion within the bandwidth that you desire. You will then use a DSP based system to adjust the transfer function to have the 'sound' that you want by adjusting the rolloff rate and the curve shape. You can replicate the signature of any alignment with this technique.
Depending on the size of the cabinet needed for this, you will need to pay careful attention to the modal resonances within this cabinet and the acoustic control methods used internally so far as they relate to the bandwidth in which it is used.
-Chris
