DJ Scotty
Is it possible to feed an external power amp out of a receiver with no pre outs? My Onkyo TX-SR600 has no pre outs, but I wanted to begin using it as a processor and get a much larger multichannel power amp (something like say 300 watts x 5) because of the ridiculously large room I'm in; is there a way around this, by perhaps feeding a "line converter" of some kind from the speaker leads or something, as in car audio setups?
Also, is it possible or recommended to add a graphic EQ to a home theater receiver to "punch up" the sound? Could this be done to DTS and Dolby Digital signals -- that is, adding equalization to spice up some of these soundtracks, or is this not recommended -- is the best route to simply play back Dolby and DTS tracks as they were "intended", that is, without any EQ applied to them and just the way they are on the DVD into the receiver?
Also, do any other Onkyo receiver owners find, even with "boosted up" calibration and "IntelliVolume" settings, that they need to bring their master volume levels to at least "50" on the display to even hear anything? I swear, below this, there is little or no impact from any DVD soundtrack, especially Dolby Digital encoded ones; DTS mixes are recorded a bit hotter, requiring a tad bit less volume applied to them, but I swear, most Dolby Digital soundtracks I play back from my DVD collection sound like *** until I reach the "50" mark on my receiver, and only then does the audio begin to "heat up"....the only problem is, I only have until the "70"'s on the display before I reach maximum volume -- this doesnt leave me a lot of room to play with, and I dont like that. Is this typical for an Onkyo amplifier section, as I have been told it is?
