Question yamaha rx-v1800 to def tec center channel
W
waxey
thinking of buying a def tec c/lr 2500 or2300 center for my system ;yamaha techs say if I hook up sub from the pre amp and and hook up the mid range to regular center out that only the sub will work. is this true.They show a y connector set up in the manual for the speaker and bi & tri wireing that I don't want to do. Thanks for your help Waxey
W
waxey
miss understood sub
I was talking about the powered sub in the center channel that accepts an rca cable from pre amp in receiver
W
waxey
Haven,t bought the speaker yet but found the 2500 for $200 less then anybody else on my digital universe.com
njedpx3
njedpx3
Connect the Def Tech to the "center out" line level with one pair of wires. Set the center speaker to large and it will get the full range of frequencies including those normally sent to sub.
I have the C/L/R 3000 and the C/L/R 2300 or C/L/R 2500 will also work great!.
Good Luck!
Forest Man
Nomo
Nomo
FYI,
the OP was talking to LOTR in this thread, not to himself:p.
Some of LOTR's posts were deleted.
MatthewB.
use speaker wire set to small and cross at 40-60Hz, otherwise you'll get distortion in that "mid bass" subwoofer.
Lordoftherings
Lordoftherings
Some of my posts got deleted!!! That's no fun at all. :(
I'm here to help people, not to distract them!
* I'm sorry waxey.
