Question to Klipsch enthousiats
kelly001
kelly001
I think I've narrowed it down to buying a pair of Klipsch Heresy speakers to go with an Onix SP3 integrated tube amp.
Does anyone have experience with various models of that line? Heresy, Heresy II and Heresy III. Are there notable differences in sound between the models? Could you define them if so.
Thanks!
corey
You might want to post your question at klipsch.com. The forum there has some people that know a lot about the vintage Klipsch lines. I'm happy with my Reference 4 speakers, but have never listened to vintage Klipsch.
highfihoney
highfihoney
I currently own Heresy 2's,KG-4's,Short Horns & K-Horns , ive owned Heresy 1's,Cornwall 1's,Cornwall 2's & most likely a few others if a really think about it.
As long as all the models are up to spec with no leaky or dried out caps in the xover system ,or damaged diaphrams in the horn drivers all 3 models will sound the same or very close,not much has changed with the Heresy in 30 years ,which is a good thing.
Others over at the Klipsch forum will argue what ive said to death,reporting so many differences between the models it'll make your head spin,i cant hear big differences when i compared them.
