Question regarding amplifier plug-in location
Being completely honest, no. Heh, that went right over my head...I believe I have always equated what you're talking about to meaning I just need different equipment. Is it possible to describe this in layman's terms/with pictures or diagrams? Sorry, I appreciate the help I'm just a bit confused.
This is what you need, the circuit on the left.
In the drawing on the left, the pre amp output is between R1 and ground. R1 is 80 K ohm. R2 is 20 K ohm. So the pre amp output is the in side and the amp input the out side.
If you don't think you can build this very simple circuit, PM me your address and I will build it for you.
