abboudc said:
Mordaunt Short lists the impedance for most of their speakers as "4-8 ohms" (only time i've ever seen a range listed) yet many receivers have a distinct 4 or 8 setting. For those of you that have these speakers, which setting do you use?
All dynamic speakers will have a range of impedance. You most frequently find the
nominal impedance cited by the specifications which will not be the minimum impedance.
Reportedly, receivers and amplifiers with a speaker nominal impedance selector tend to use it just to enable a current limiter for higher volumes on the lower impedances. In other words, they don't do very much except protect you from yourself
So, in this case, just leave your receiver's impedance setting at eight ohms.
