Question for the Experts
jdedge
I'm shopping to buy a Denon 4306 for my HT-Would you guys buy a B stock item from an authorized B stock dealer-say dakmart- OR would you go for the A stock item from a good eBay dealer? Price is about the same-so cash would be left over for any needed repairs.
Thanks for any insight.
jcPanny
jcPanny
Warrantee
You wont have a warrantee if you buy through ebay, and you usually have a short 90 day warrantee through Dakmart.
You might check what kind of deal you can get from a local dealer if you want A stock with a warrantee.
tomd51
tomd51
I would stick w/one of the authorized refurbished dealers such as Dakmart, eCost or uBid. If something does happen w/the receiver, it's likely to occur within the first few weeks of use.
Dakmart usually offers a 1 year warranty as opposed to the standard 90 day refurbished warranty, but they also typically jack up the price a bit to compensate for the added warranty... -TD
jdedge
Thank you
I appreciate the insight gents-Have a blessed week.
