No measurements. Would have been interesting though.
The room was 40x40, so the sub was on the left wall, half way back, and 3' from the wall. No bass traps. We actually moved the sub to that position, knowing it was a weak point to put a sub. Keep in mind, this is a huge room. The specs on this thing are amazing. The EQing or controls are behind the grill. See photo below.
Frequency Response: 18–150 Hz ±3 dB
Anechoic through LFE input.
Input Impedance: 20,000 ohms
Crossover Frequency : 40, 70 Hz
Phase: 0°, 90°, 180°, 270°
25Hz Level Control: ±12 dB
Woofer type: 3 x 10" (25.4cm) high excursion, aluminium core cones with extended throw driver assembly in a BalancedForce™ array
Amplifier: 400 watts rms (800 watts peak) 0.07% THD
Inputs: RCA Line Level; RCA and XLR LFE
Output: RCA
Weight: 95 lbs
(43.2kg)
Dimensions: 21.75" H x 20" W x 18.25" D
(55.3 x 50.8 x 46.4cm)
