It might sound like my last question, i am just confuse about it, because i read someone mention adding a DAC between PC to receiver can convert the sound better into 5.1.
Currently, i am running many issue with my setup.
I brought an output digital cable, only found out that it only does PCM 2.0 i can't get it to output 5.1 at all.
Secondly, i use my Radeon 5850 HDMI output only to find it disable my 2nd monitor, i am thinking buying a displayport to enable it back.
and thirdly, It flicker my monitor using HDMI whenever i turn the power on/off. Which is annoying when i switch source and back, it will also disable the HDMI audo from PC until i restart the receiver on/off again.
