Question/ connector
moreira85
I just ordered the Behringer Feedback destroyer. In order to hook this up the input and output on the BFD uses 1/4 inch mono connection.
My question is do i have to order 2 new sub cables with RCA on one end and
1/4 inch on the other, or can I use these below.
If I use these will I be loosing some of the signal because of the connector?
http://www.amazon.com/gp/product/B0018SW3WQ/ref=s9_simz_gw_s0_p267_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=007E6P65F3J6J997MYG5&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
bombarde32
Generally speaking (IMHO) each connection point is an opportunity for something to go wrong. That being said - a tight connection between quality components isn't a problem in and of itself.
Not familiar with these plugs though. Anyone else seen these or have a recommended alternative? I flipped through bluejeanscable really fast but I didn't see them on there.
moreira85
well the behringer 1124 can use 1/4 inch or XLR. I noticed that monoprice has RCA to XLR. I will have to be one male XLR for input and 1 Female XLR for outut. Do you think XLR would be okay?
agarwalro
agarwalro
The RCA to XLR cable or a XLR to RCA Female converter piece with RCA cable will work just fine. The cable is a better solution since there are less points of loose contact or breakage.
