Let's say a material has a higher inherent resistivity to start out with (say 2.57 x 10^-7 Ohm . m, which is an order of magnitude higher than Copper's 1.7 x 10^-8 Ohm . m). But in the same temperature region, the resistivity of this material increases at a rate lower than Copper's, meaning it has a lower Temperature Coefficient of Resistivity.
My question is if this material has a higher specific conductivity (conductivity:mass ratio) than Copper and Aluminum, will it perform better as a voice coil, in terms of efficiency, sensitivity, thermal, and magnetic compression?
Basically, I'm trying to learn what the benefit is to a lower mass voice coil (with higher resistivity, lower TCR, and higher specific conductivity) vs. a higher mass voice coil (with lower resistivity, higher TCR, and lower specific conductivity).
Thanks
