Question about the Yamaha RX-V371 and DTS-HD Master Audio
blackalert
Hi, I just purchased the Yamaha RX-V371 and just noticed through some reviews that this receiver doesn't have DTS-HD Master Audio and only has DTS-HD High Resolution? I purchased it on Newegg and it said it had DTS-HD MA, but now I don't know what to believe.
The Yamaha site for the RX-V371 states this for the DTS-HD,
DTS-HD® featured products have the ability to decode all streams required for DTS-HD Master Audio™ but may have limitations in channel output and/or sampling frequency; or may utilize unique post processing.
Does that mean it does or doesn't?
So right now I have my PS3 producing the DTS HD Master Audio. My question basically is since I guess this receiver can't produce DTS HD Master Audio, but my PS3 can, does it even matter? Just wondering if I should return this receiver and get a different one or just keep it.
Thank you in advance
bikdav
I Can Only Offer a Theory
This whole Blu-ray issue is very confusing at best. I'm not sure about this, but the way that I think it works is that if your PS3 has a DTS-HD decoder in it, it should do the decoding instead of the receiver. In the ideal situation, you should get the DTS HD sound. BUT, I just recently learned [if I understand it correctly] that some Blu-ray producers have some program on the disc to block that function for copy-write reasons.
May be it matters. If your PS3 can send it as LPCM to your receiver, all will be OK. But as has been pointed out you may run into DRM issues.
DTS HD streams at 6.0 Mbps, and Master HD at 24.5 Mbps. So there is about a four to one data loss with DTS HD.
My advice is to ditch that receiver, depending on whether your speakers have the resolution to tell the difference.
Personally I like loss less codecs.
GlocksRock
GlocksRock
I don't believe this receiver will decode master audio, it likely will take a dts-hd ma and output it as dts-hd high resolution, but if your ps3 is decoding the dts-hd ma and outputting it as pcm then you are getting the full resolution of audio. The old fat PS3 can't output bitstream, but the slim ones can, so depending on which PS3 you have, it may not really matter about the receiver not being able to decode the master audio. However, with blu ray playback on my PC using PowerDVD 11, I can hear differences in the audio when letting the software decode the audio and output as PCM vs bitstream output with the receiver doing the decoding. So my reccomendation is that if you have a slim ps3, return the receiver and get one that does decode the master audio portion of the bitstream and set your ps3 to output bistream. Look on the yamaha website and where you see the receivers details, look for the dts hd logo, and if you see master audio under the words dts hd then you are good to go.
avnetguy
avnetguy
FWIW, the RXV371 owners manual states it decodes DTS-HD Master Audio.
Steve
GlocksRock
GlocksRock
I guess the only way to know for sure what he is getting if for him to use a player that can bitstream the output and see what lights up on the receiver.
