Question about the best way to setup PS5, TV, and Receiver
DudE132
This is a bit long but I'm trying to learn more about TV's and receivers so please bare with me.
I've been using my PC setup for everything so I've never had a need for a TV (I have no experience with modern TVs as a result) and my receiver knowledge has been pretty basic in terms of hooking things up due to the simplicity of my setup. Currently I have my setup like this between my PS4, Monitor, and Receiver...
PS4 -> Receiver via Optical
PS4 -> Monitor via HDMI
This setup will not work with the new PS5 because unlike the PS4, the PS5 does not have an optical port. I plan on buying a TV and PS5 at some point and am trying to learn more about how the setup would work best. One option with a PS5 setup would be this...
PS5 -> Receiver via HDMI
Receiver -> Monitor via HDMI
But I would much rather have my PS5 connected straight to the TV to avoid any input lag or video processing from the receiver which may degrade the picture quality/performance. Some receivers have minimal processing or even settings to disable processing but I'd rather bypass the entire thing by connecting the console directly to the TV. This is where I'm trying to learn more about ARC and eARC. I've never had a TV and never used ARC so I'm a bit unsure. Here is the setup that I'm thinking would work best...
PS5 -> TV Via HDMI
Receiver -> TV via HDMI ARC/eARC
With this setup, since the PS5 is connected directly to the TV while the Receiver is connected to the TV via ARC/eARC, would this mean that the Receiver is ONLY responsible for audio and as a result will have no impact on the video output?
L
Leemix
Yes.
Does your AVR support ARC/eARC?
What model is it?
Lag wouldn't particularly affect picture quality, mostly a gaming thing....then there are possible sync issues separating the audio/video. Should be easy enough to simply pass thru the hdmi video without processing in the avr.
DudE132
I did read about some potential sync issues with ARC. Would those still be present if I did this as an alternative with optical instead?
PS5 -> TV Via HDMI
Receiver -> TV via Optical
On another note I've read that some receivers could still negatively alter the video quality even while bypassing video processing via the settings. Then there are receivers like mine (Anthem MRX500) which have a ton of awful processing but appear to have no way to bypass them when the receiver is passing video. I might upgrade my AVR in the future and this is making it seem overly complicated. When researching receivers they don't state whether or not video processing can be bypassed. The last thing I want is the AVR altering the picture quality with it's own brightness, contrast, sharpness, grain, smoothing and potential lag on top of that. Gaming is the primary focus so unaltered video is important for me.
I was hoping to just avoid this headache entirely buy plugging the console directly into the TV and using ARC/eARC for audio.
