Thanks. One follow up.
gene said:
The Sunfire amp uses a track down converter and Class H topology to increase efficiency. !
Oh. Yeah, that's what I was gonna say.
gene said:
Despite what the literature claims, the amp cannot drive 400wpc continuously with all channels driven, not that this is a real world scenario to begin with. . . . Divide that up to 7 channels and you get about 155wpc NOT 400wpc!
Ok, that part I can understand.
Also, I just found this quote in a post from a Sunfire owner over on AV123: "In Sunfire's application of Class H they eliminate most of the heat sinking because it's not needed; Emo not only includes heat sinking but fans as well, and I just wondered why that was, since they both use variable rail volatages."
So maybe that accounts for some of it, but probably most is the power supply, I guess.
Anyway, suppose I put aside their shameless puffery regarding the all channels driven spec. Recognizing that I will never actually even listen at 7x200, let alone 7x400, will it still not sound as good at reasonable listening levels? I would guess only the 2 fronts and the center will ever be driven to any substantial continuous volume. The smaller size is very appealing, but I don't want to give up any sonic quality, especially since it's pricier.
